| 92 NA with 84k Tried search but this problem was not found Problem - Just recently this started, at a restart about 30 minutes after car was shut off from a complete warm up the engine sounds and feels like it is running on 5 cylinderes and after about 30 seconds it clears up and all is fine for the rest of the run until the next time it is shut off and restarted when warmed up. No problem yet at a complete cold start. Plugs were replaced at 60k with NGK correct # No vacuum leaks, 20"hg at idle with steady needle PCV's and hoses were changed back at 60K Throttle bodies cleaned Fuel filter changed at 69k Air filters are clean Recently put Seafoam in gas, no results yet My thoughts: injector going out fuel pressure regulator out of spec fuel damper problem intermittent coil problem carbon on a spark plug EGR slightly open Any ideas on what to check is appreciated TIA
ZUL8TR in Orlando,FL |
